HP ZBook 15 G4 Mobile Workstation cpw50 LA-E161P
Discussion in 'BIOS/UEFI' started by technical, Sep 10, 2018.
    cpw50 LA-E161P
    BIOS P70_0123
    Similar Threads - ZBook Mobile Workstation Forum Date
    HP-Compaq HP ZBook Studio G3 Mobile Workstation LA-C401P APW5U Rev:1A BIOS/UEFI Mar 29, 2019
    HP ZBook 15 G3 Mobile Workstation BIOS APW5U LA-C401P BIOS/UEFI May 14, 2018
    HP ZBook 15u G3 Mobile Workstation BIOS BIOS/UEFI May 8, 2017
    HP ZBook 17 G3 Mobile Workstation LA-C391p BIOS/UEFI Dec 28, 2016
    Bios HP Zbook 14-G2 Mobile Workstation BIOS/UEFI Nov 28, 2016
  3. Kahal
    Kahal New Member
    Hi.
    I have programmed this file on my zbook 15 g4 in order to remove the password. But I get blank screen with this file. So, your file did not work for me.
    Can you please remove the password from my file.
    Thanks for your support
  5. Kahal
    Kahal New Member
    Thanks for quick reply. I programmed the file that you sent me but unfortunately the password is still there! :(
    When I powered the laptop on after I programmed the file I got a message that "BIOS has recovered itself ....".
    Programming bios i send you and take one photo display request password.
  7. Kahal
    Kahal New Member
    Sorry for replying late. Here is the picture of the message that I get in the first boot after programming your "unpass" file. It requires a password again.
    6. 18.
    yes here
  9. Kahal
    Kahal New Member
    Hi. Thanks for trying to help me. But this file (P70.bin) did not work. After programming I got nothing on screen, it is completely black. I even left the laptop on for more than 10 minutes to see if the problem is ME Region. But nothing.
    Any other suggestion?
    can't be like that. returm old laptop have working ?
  11. Kahal
    Kahal New Member
    The laptop works with its original BIOS file but have password. I tested your files again and it does not work. I think the laptop change the code inside the BIOS after first boot. I am stuck at this point !
    now returm old work or not send one photo display request password.
    I doubt there is a problem when you program...
  13. Kahal
    Kahal New Member
    Hi. In the past few days I have checked all the files that you have sent to me. I programmed the old BIOS file and it still requires password. Do you think the password is stored in the IO chip?
    I appreciate your help. Thanks
  14. 01ifix
    upload your dump here i try to help you
  15. Kahal
    Kahal New Member
    Thanks for replying me. Here is the original bios file.
  16. 01ifix
    try and let me know result
  17. Kahal
    Kahal New Member
    Thanks for helping me. Unfortunately my VIP has just been expired. Can you please upload it somewhere. If not I have to upgrade my account again.
  18. sophen
    sophen Well-Known Member
    Hp zbook studio G4 mã main CPW5U LA-E251p rev:0.5.Bios backup từ máy đang chạy đóng qua máy khác không lên Admin clear me thử giúp
  20. thales tadeu
    thales tadeu Well-Known Member
    Hello friend, can you remove the password from the bios please?
