IBM-Lenovo LENOVO A540 - A740 ALL-IN-ONE LA-B031P
Discussion in 'BIOS/UEFI' started by technical, Jul 27, 2015.
    BIOS 128KB & 8MB - O14KT15AUS
    Refer to steps below to identify the platform of your machine:
    1.Power on the unit, press F1 to enter BIOS Setup
    2. Check BIOS Revision Level:
    • If the BIOS Revision Level is O14KTxxAUS, it is Broadwell system.(xx means actual BIOS level, such as O14KT15AUS)
    • If the BIOS Revision Level is O00KTxxAUS, it is Haswell system.
    a740a540bios_setup.
    Lenovo A540, A740 All-in-One
    Schematics A740 A540 LA-B031P r0.1
    LA-B031P.
    ZAA5 70 LA-B031P REV 20 Discrete 8MB 128KB
    >> LENOVO BIOS
    #1 technical, Jul 27, 2015
    Similar Threads - LENOVO A540 A740 Forum Date
    Lenovo AIZS1 LA-C582P BIOS/UEFI Oct 5, 2021
    BIOS PC lenovo yoga 310s-11iap BIOS/UEFI Mar 5, 2020
    Lenovo IdeaCentre AIO 520-24ARR ECA20 LA-F902P r1.0 BIOS/UEFI Nov 16, 2019
    Lenovo S130 / S130-11IGM clean ME BIOS/UEFI Aug 21, 2019
  3. MOBOKAP
    MOBOKAP Well-Known Member
    HI, you have bios and EC for Lenovo AIO A740, main LA-B031P ZAA50/70 rev: 1.0 2014-02-25 whith Haswell I7- 4558U O00KTxxAUS ? O14KT15A is for broadwell.
  5. niggar
    niggar Well-Known Member
    KB9012QF A4 EC bios needed up above not working board LA-B031P REV 1.0
    EC O14CT19A.
  7. niggar
    not working same before
    same before is bios good you,
    you need check hardware.
  9. niggar
    only kb9012qf is damaged so i change when i program with LA-A341P KB9012 EC POWER ON IS WORKING BUT TURN OFF AFTER 5 SECOND AND NO DISPLAY BUT YOUR SITE EC BIOS POWER SWITCH IS NOT WORKING ....
    what? LA-A341P or LA-B031P ?
  11. niggar
    :broken_heart:I NEED LA-B031P EC BIOS FOR KB9012QF A4 BUT I TRY LA-A341P ONLY FOR TEST OTHER HARDWARE .....WHY DON,T YOU UNDERSTAND SIMPLE ENGLISH
    new update on top new file you can try again
  13. niggar
    THIS 128KB NOT EC IT IS NEAR TO LAN HAVE CHIP 25X10
    send file ec old you say i check
  15. niggar
    OLD KB9012QF A4 NOT READING IT'S DAMAGE
    send file 25X10 i check.
    how you know 128kb above is for 25X10 ?
