820-00239 X362 MLB SCHEMATIC A1706 schematic
Discussion in 'Schematics' started by technical, Aug 10, 2017.
    X362 MLB SCHEMATIC 820-00239
    A1706 schematic
    MacBook Pro 13" A1706 Touch Bar (Late 2016) 820-00239-09
    A1706.
    xtohin, sanleo25 and Macfixit like this.
    Similar Threads - 00239 X362 SCHEMATIC Forum Date
    ASUS ZenBook Flip 13 UX362FA BIOS/UEFI Dec 16, 2018
    820-00239-A
  4. tam tran
    tam tran Well-Known Member
    Mã main của em là 820-00239-A nhưng em nạp bản 820-00239-A me của web mình thì ko có nguồn cpu, riêng bản MacBook Pro 13" A1706 Touch Bar (Late 2016) 820-00239-09.zip thì lại có nguồn cpu nhưng quạt ko quay và ko lên hình. Vì máy này thợ nào vứt bỏ con bios, Ad có bios nào giống mã main của em ko cho e xin ạ. Thanks
    thử fie post 2 từ trên xuông xem sao bạn.
  6. tam tran
    EM ĐÃ THỬ LUN ROÀI KHÔNG DC ANH.
  7. eplanet
    eplanet Well-Known Member
    your bios is ok but language is other can you do in english ..
    all language can change
    Screen Shot 2019-05-07 at 8.05.14 PM.
  9. eplanet
    i know this but here language is different
    next ?
  11. eplanet
    how can i install mac bcoz language is different
    after where setup MacOS use language you want all will be fixed
    and two bios on top i not see you downloads, you can try If you don't want to reinstall MacOS..
  13. eplanet
    ok
  14. JENTORIS
    JENTORIS Well-Known Member
    [QUOTE = "ThienBui, post: 66731, member: 6"] X362 MLB SCHEMATIC 820-00239
    A1706 schematic
    MacBook Pro 13 "A1706 Touch Bar (Late 2016) 820-00239-09
    [ATTACH = full] 64991 [/ ATTACH] [/ QUOTE]
    Clear ME Please?
  16. JENTORIS
  17. JENTORIS
  18. JENTORIS
  20. JENTORIS
    same problem, and also fan not spinning at all.
    sure hardware have problem.
