HP-Compaq HP ProBook 450-G2 LA-B181P
Discussion in 'BIOS/UEFI' started by technical, Apr 26, 2015.
    send bios old no display i check.
  2. ct lab
    ct lab Well-Known Member
    old bios
    try
    hp 440 G2 LA-B181P vina build.BIN
  4. ct lab
    hi sir,bios flash hp 440 G2 LA-B181P vina build.BIN but at now problem ,,,,,f1 continue shut down
    I think all is good.
  6. 42ifix
    42ifix Well-Known Member
    clear me please
    42ifix likes this.
  8. umali143
    umali143 Well-Known Member
    sir i need la-b181p me bios
    this is old bios dump
    • old.BIN
      8 MB
      12
    above Available you.
  10. umali143
    la-b181p m73 me bios working plz
    yes, bios above working..
  12. 07ifix
    07ifix Moderator
    Dear ThienBui,
    Please Find Attachment i am send u the pic of laptop displayed which is not detecting the hard disk drive properly. i tried 6-7 Different bios to solve this issue but its not working. before that issue laptop was not giving the display but that issue solved with the new bios but it giving issue of hard disk. Now we also don't have old bios with us now. give me solution for that problem as soon as Possible.
    Regards
    old bios fpr laptop error what, you have save before ?
  14. bruce
    bruce Well-Known Member
    please clear me this file please
    clear me_OLDGOOD.bin
  16. 07ifix
    07ifix Moderator
    well in old bios it was some time witched but didn't give display and also it even dont turn on some time that time.
    and i also don't save the old bios. so kindly solve my problem as soon as possible. and send me the bios for this solution. thanks
    Regards
    you need check add hardware, above many bios can not error all.
  18. APPLE CARE
    APPLE CARE Well-Known Member
    broadwell platform not supported
    platform incompatible (999) error SOLUTION plz
    check right info and use right bios, you have old error bios save ?
  20. APPLE CARE
    no already came from other shop they already uninstall the bios
Similar Threads - ProBook B181P Forum Date
Bios HP ProBook G450 G2 Dis LA-B181P Rev:1.0 BIOS/UEFI Apr 23, 2017
