HP ZBook 15 G3 Mobile Workstation
Discussion in 'BIOS/UEFI' started by technical, Aug 5, 2016.
    why you send and request i remove password ?
  2. iTecWireless
    iTecWireless Well-Known Member
    I didn't even check if the BIOS HAD DATA OR NOT. I read few times, and i sent you, that's all.
    but bios not work how you know it have password ?
  4. 13ifix
    13ifix Moderator
    sir do you help me when i put hdd its restart mahine again and again i change 3 or 4 hdd same issue is it bios issue or some other thing tell me what the issue
    can give one video problem ?
  6. 13ifix
    13ifix Moderator
    when i put the
    why video not uploaded
    zip and update, or size big you need use googlr drive..
  8. 13ifix
    13ifix Moderator
    when put hdd
  9. 13ifix
    13ifix Moderator
    when i remove hdd
    I think there is a problem with HDD management circuit and south bridge chipset...
  11. 13ifix
    13ifix Moderator
    k thanks
  12. simolife
    simolife New Member
    i want the bios of this motherboard
  13. yoav
    yoav New Member
    Can I get the bios of the video card quadro m2000m ?
    From Zbook 15 g3
  15. trollis69
    trollis69 New Member
    will you be able to help with the third chip .bin file? GPU (vieo) for this laptop, with motherboard APW5U LA-C401P, need 1Mb .bin for Winbond 25Q80
    VGA can not have bios 1MB, send file bios and location chip i check.
  17. trollis69
    HP ZBook 15 G3 Mobile Workstation, with MB: APW5U LA-C401P is a contain 3 bios chip's,
    Front side board - 25Q80DV, 25Q128FV (MAIN), backside board: 25Q64FVIQ (EC)
    from you, only 16Mb and 8Mb .bin files are available for download, need the third is 25Q80DV 1Mb. chip damaged, old file not available.
    Unavailable file 1mb this, but sure it not for card quadro m2000m.
    wait i find...
    Turco44 likes this.
  19. trollis69
    Hi, are there any news about it?
Similar Threads - ZBook Mobile Workstation Forum Date
HP-Compaq HP ZBook Studio G3 Mobile Workstation LA-C401P APW5U Rev:1A BIOS/UEFI Mar 29, 2019
HP ZBook 15 G4 Mobile Workstation cpw50 LA-E161P BIOS/UEFI Sep 10, 2018
HP ZBook 15 G3 Mobile Workstation BIOS APW5U LA-C401P BIOS/UEFI May 14, 2018
HP ZBook 15u G3 Mobile Workstation BIOS BIOS/UEFI May 8, 2017
HP ZBook 17 G3 Mobile Workstation LA-C391p BIOS/UEFI Dec 28, 2016
