Apple A1466 EMC 2925
Discussion in 'BIOS/UEFI' started by 01ifix, Feb 3, 2017.
  1. 01ifix
    hi i have this macbook air A1466 EMC 2925
    have password see picture below
    how can read BIOS and write without password ?
    this bios is solder special my programmer is model minipro tl866a
    help me admin . thenbui ?
    Similar Threads - A1466 2925 Forum Date
    Macbook Air 13 inch A1466-EMC 2925-820-00165-A-Early 2015 BIOS/UEFI Jan 4, 2017
    Apple A1466 Schematics Dec 17, 2018
    A1466 BIOS/UEFI Oct 15, 2018
    A1466 820-00165-A BIOS/UEFI Apr 23, 2017
    Apple A1466 820-00165 A BIOS/UEFI Aug 7, 2016
    Tutorial here
    https://vinafix.vn/resources/how-to-remove-password-bios-apple-add-edit-serial-number.1209/
    Unlock - How to remove password Bios Apple & Add, edit Serial...
    Manual document .pdf 1. Use tool ( TL866 or 610P ...etc ) backup BIOS has password. 2. Open BIOS use software HxD remove password. 3. Done and Programming. You need to be a hardware technical to...
    vinafix.com
  4. 01ifix
    tutorial have schematics how solder wires for dump the bios without desoldering ?
    thanks
    No, Tutorial only guide remove passord in file dump.
  6. 01ifix
    BIOS special how can dump bios without remove bios ? some like this
  8. 01ifix
    only works with tsop 28 ?
    All stop. same pin name...
  10. vien
    vien Well-Known Member
    ad cho xin bios mac book pro emc 2351 tk nhieu
    Mã main đàng hoàng chứ, EMC 235 có mà đầy máy chung EMC...
  12. vien
    Apple MacBook Pro Core 2 Duo 2.4 13 Mid-2010 EMC 2351 BIOS CHO EM CON NAY
    không có main hả?
    tim 820-xxxxx ?
  14. vien
    820-2565-a
  15. jarus
    jarus New Member
    hi i need you to remove the password
    a1466 emc 3178 2017
    motherboad code ?
  17. jarus
    jarus New Member
    820-00165-A
    unlock 00165
  19. abdallahamer
    abdallahamer Well-Known Member
    Please remove this password file A1466 EMC 2925 820-00165-A
    I have purchased the method of remove the password and I tried it and did not work,
    Knowing that I've tried it on previous mac and worked .
    Thanks,
